Unable to Bind to an I/NET Point
  • Unable to Bind to an I/NET Point
  • Derrick_Ratliff
    Derrick_Ratliff
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 10:02 AM
Command Error Alarm after Binding to an I/NET Value
EcoStruxure Building Operation, TAC INET
StruxureWare Workstation
As of version 1.4, I/NET input points can not be bound to SmartStruxure outputs.
A Command Error Alarm will occur when attempting to bind to an I/NET controller that does not have the current bin file
  1. If needed create an additional I/NET output point and use that to control the I/Net input point via a Calculation Point Extension.
  2. In I/NET, connect to the controller.
  3. Select Edit > Controller > Configuration
  4. If the Build Date is older than April of 2012, you will need to upgrade the controller.
  5. In StruxureWare, when setting up the bind to the I/NET point, be sure to edit the I/NET point objects bindings, if that is what is being controlled.
  6. Bind the desired StruxureWare value to Control Value (DO) or Value (AO) property of the point for I/NET.
Labels (2)
  • TAC INET
  • 14483
