USB-serial adapter recommended for use with DMS Operator interface (OPRIF) version 11.6
  • USB-serial adapter recommended for use with DMS Operator interface (OPRIF) version 11.6
‎2018-09-06 02:10 PM
USB-serial adapter recommended for use with DMS Operator interface (OPRIF)  version 11.6.
DMS OPRIF 11.6, DMS-350A and DMS-3500
Lack of serial port on PC.
We recommend the IOGEAR model GU232A.
(This is the same adapter we recommend for use with other devices, such as the
MSC-LIM, MN-CIM and CBL-002 (DB-9S>DB-9S).
NOTE: When using the converter with the MSC-LIM, launch the OPRIF from the LINKERGL.EXE in the DMS folder.
  • TAC IA Series
  • 4524
100% helpful (1/1)
