USB port on STD300
  • USB port on STD300
  • SESA150559
    SESA150559
USB port on STD300
‎2018-09-06 09:42 AM
What is the USB port used for in the STD300?
STD300
Internal hardware upgrade that does not affect the functionality.
The USB port is in place for internal/factory use only, and should not be used in the field.
  • Field Devices
  • 15577
