USB converters used with computer and interfaced equipment
  • USB converters used with computer and interfaced equipment
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-10 03:53 AM
My computer has USB ports, but it does not have serial or com ports. Can I use USB ports?
For I/NET, Host computer that either Direct Connects (cable 072) or you need to connect to a controller such as a 7798C (cable 082)
Continuum, Vista, Sigma, I/A Series, Pelco, DVR, DS, Com Port, Com, PTZ Control, Serial Port, Comm, Comm Port
USB to Com has issues downloading or communicating with system.
The generic drivers which came with your USB to Com adapter do not allow two-way communication.
Prolific driver often helps resolve this issue. Download driver HERE or for the latest driver use link below:
http://www.prolific.com.tw/US/CustomerLogin.aspx    you will need to logon as GUEST
Labels (8)
  • CCTV
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
PL2303_Prolific_DriverInstaller_v1.12.0.zip
  • 6533
