US Robotics 56k V92/V90 Modem Settings (Non - NPR Dial)
  • US Robotics 56k V92/V90 Modem Settings (Non - NPR Dial)
  • sesa139513
    sesa139513
‎2018-09-06 03:28 PM
I/NET site with need for Modem
What are the US Robotics 56k V92/V90 Modem Settings (Non - NPR Dial) settings?
DIAL = TONE B0 F1 M1 X0
BAUD = 9600 PARITY = N WORDLEN = 8
&A0 &B1 &G0 &H0 &I0 &K0 &M0 &N6 &P1 &R1 &S0 &T5 &U0&Y1
S00=001 S02=043 S03=013 S04=010 S05=008 S06=004 S07=060 S08=002 S09=006 S10=014 S11=070 S12=050 S13=000 S15=000 S19=000 S21=010 S22=017 S23=019 S25=005 S27=000 S28=008 S29=020 S30=000 S31=128 S32=002 S33=000 S34=000 S35=000 S36=014 S38=000 S39=000 S40=001 S41=000 S42=000
  1. Set the configuration at the Host Modem and site Modem to the same configuration as shown above.
  2. Take out any initialization strings you may have added in windows “ Phone and Extra Settings” dialogue.
  3. Select “Change Default Preferences” in the same dialogue and change the defaults to port speed 9600, Data Protocol to Standard EC, Compression disabled, and Flow Control to none.
  4. Make sure in the Modem properties dialogue to Maximum Post Speed is set to 9600 baud. This needs to be performed for the Host Modem and Site Modem.
  5. Switch settings 1, 5, 6, 7 are in the “UP” position.
Note: Non - NPR Dial
Note: US Robotics 56k faxmodem V92 and V90 standard technologies PN:USR5686E
  • TAC INET
  • 994
