URL to a Xenta Server that bypasses the log in
  • URL to a Xenta Server that bypasses the log in
  • sesa119747
    sesa119747
  • sesa150555
    sesa150555
‎2018-09-06 02:32 PM
Is there a way to link to a Xenta Server so you don’t have to log in to it?
Xenta Server
Xenta 511, 527, 701, 711, 721, 731, 913
Access to Xenta Server with auto log in is not a supported feature.
There is no auto log in function in the Xenta Server but you can add the password to the URL
https://xx.xx.xx.xx/www/index/index.html?UID=root,PW=root
This will log you in and take you the start page for the user
You can also go direct to a page (TGML, Trendlog etc.), this way you will not get any other frames.
First you have to figure out the path to the page. Easiest way to so this is to log on the 731 with FTP and browse to the graphic you want to display.
Copy the path and add ?UID=root,PW=root (for root user)
Here is an example what it might look like
https://172.20.10.91/www/info/The+site+name/Folder+2/Graphic_page.html?UID=root,PW=root
Note that if you use this method the user can not log out (the user will still be logged out after the default time still)
  • 3675
