Types of TAC Erie Pop Top valves and actuators available from Schneider Electric in the UK
  • Types of TAC Erie Pop Top valves and actuators available from Schneider Electric in the UK
‎2018-09-10 11:12 PM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:54 AM
Field Devices
  • Pop Top Valves
  • Pop Top Actuators
Actuator Part no's available in the UK
Valve Part No's and connection types available in the UK
ZY valve and actuator replacement
Actuators
AH13U230 - High Close Off - Spring Closed 230Vac Actuator c/w 36" Lead
AH13U23A - High Close Off - Spring Closed - 230Vac Actuator c/w 36" Lead + Aux Switch
AG13A230 - Spring Closed - 24Vac Actuator c/w 36" Lead
AG13A23A - Spring Closed - 24Vac Actuator c/w 36" Lead + Aux Switch
AG13U230 - Spring Closed - 230Vac Actuator c/w 36" Lead
AG13U23A - Spring Closed - 230Vac Actuator c/w 36" Lead + Aux Switch
AG23U230 - Spring Open - 230Vac c/w 36" Lead
AG23U23A - Spring Open - 230Vac c/w 36" Lead + Aux Switch
AG23A230 - Spring Open - 24Vac c/w 36" Lead
AG23A23A - Spring Open - 24Vac c/w 36" Lead + Aux Switch
Valves (Note:NPT is American connection)
VT2222 - 2way - 1/2" NPT 2.5Cv
VT2223 - 2way - 1/2" NPT 3.5Cv
VT2231 - 2way - 1/2" BSP 1.0Cv
VT2232 - 2way - 1/2" BSP 2.5Cv
VT2233 - 2way - 1/2" BSP 3.5Cv
VT2325 - 2way - 3/4" NPT 5.0Cv
VT2327 - 2way - 3/4" NPT 7.0Cv
VT2332 - 2way - 3/4" BSP 2.5Cv
VT2333 - 2way - 3/4" BSP 3.5Cv
VT2335 - 2way - 3/4" BSP 5.0Cv
VT2337 - 2way - 3/4" BSP 7.0Cv
VT2437 - 2way - 1" BSP 8.0Cv
VT3231 - 3way - 1/2" BSP 1.5Cv
VT3232 - 3way - 1/2" BSP 3.0Cv
VT3233 - 3way - 1/2" BSP 4.0Cv
VT3332 - 3way - 3/4" BSP 3.0Cv
VT3333 - 3way - 3/4" BSP 4.0Cv
VT3335 - 3way - 3/4" BSP 5.0Cv
VT3337 - 3way - 3/4" BSP 7.0Cv
VT3437 - 3way - 1" BSP 8.0Cv
Erie™ PopTop™ Series Valve Bodies and Actuators - Installation Instructions.pdf for the VT and VS valve, AG and AH actuator.
Note: Only those listed above are available in the UK.
  • Field Devices
Tags (4)
  • 11952
  • DavidChild19
  • poptop
  • zone
