Trying to serial tunnel with XPSI through an I/A Series G3 (Niagara) ENC, get error message: "Could not connect: tunnel unknown by server."
  • Trying to serial tunnel with XPSI through an I/A Series G3 (Niagara) ENC, get error message: "Could not connect: tunnel unkno...
  • SESA113595
    SESA113595
‎2018-09-10 04:54 AM
I/A Series G3 (Niagara) ENC with connected ASD bus
PSI/XPSI software
The Tunnel Identifier in the ENC station and the Tunnel Name in the Niagara AX Serial Tunnel Client do not match.
Copy the Tunnel Identifier from the ENC station and paste it into the Tunnel Name of the client to insure an exact match.
Properties of the Psi Tunnel, under the AsdNetwork
  • TAC IA Series
  • 6672
0% helpful (0/1)
