Trend Calculation - Can the value be used in a program like FBP or script
  • Trend Calculation - Can the value be used in a program like FBP or script
  • sesa150561
    sesa150561
‎2018-09-06 09:42 AM
Use the trend calculation value in a program like FBP or script.
StruxureWare Building Operation 1.4.1
Once a value has been calculated by a trend, it might be useful to pull it into a piece of programming.
Unfortunately, this is not possible. The Value of a Calculated trend is only accessible from the viewer as a chart or list.
Tags (3)
  • 15608
  • block
  • function
