Translating "large" key/card numbers (i.e., numbers greater than 24,000) directly to a lower number
  • Translating "large" key/card numbers (i.e., numbers greater than 24,000) directly to a lower number
‎2018-09-06 11:01 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:20 AM
Is I/NET capable of translating “large” key/card numbers (i.e., numbers greater than 24,000) directly to a lower number?
I/NET site with access control
The I/NET system is capable of translating “large” key/card numbers (i.e., numbers greater than 24,000) directly to a lower number, without the use of the Key/Card Translation table.
However, this functionality requires that the SLI and DPU binary loads are I/NET 2000 revision 2.x or I/NET Seven revision 1.x (or later) compatible, and that DIP switch 7 at the DPU is ON.
For DPUs with earlier firmware versions, the use of the Key/Card Translation table is still required when key/card numbers are greater than 24,000. Refer to TCON300 for more details.
  • TAC INET
  • 1229
