Transformer for I/NET Controllers
  • Transformer for I/NET Controllers
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-10 06:28 PM
  • XFMR1, XFMR2, XFMR3, XFMR4, XFMR5, XFMR6, XFMR7, XFMR8, XFMR9, XFMR10, XFMR11
  • IRB8, IRB8HC Relay boards
  • 7700, 7740, 7741 DCUs
  • 7750, 7760, 78XX, 72XX UCs, 7716
  • 7718, 7780, DPU3100, DPU7910A, DPU7920
  • 78XX TAPs
  • 7780 DLCU
  • 7728 I/SITE I/O
The following table describes each transformer, the primary power required, the secondary power supplied by the transformer and the products each transformer model supports. Some of these transformers have two secondary outputs and these are shown in the table.
Download the attached PDF document here.
Model Number Description Comments
XFMR1 Transformer, 120Vac Primary, 20Vac @ 3.4A Secondary IRB8, IRB8HC Relay boards
XFMR2 Transformer, 120Vac Primary, 10Vac @ 3.6A and 36Vac @ 0.7A Secondaries 7700, 7740 7741 DCUs
XFMR3 Transformer, 240Vac Primary, 10Vac @ 3.6A and 36Vac @ 0.7A Secondaries 7700, 7740, 7741 DCUs
XFMR4 Transformer, 120Vac Primary, 13.5Vac @ 2A and 24Vac @ 2A Secondaries 13.5Vac for baseplate mounted 7750, 7760, 78XX. 24Vac for 72XX UCs, 7716
XFMR5 Transformer, 240Vac Primary, 13.5Vac @ 2A and 24Vac @ 2A Secondaries 13.5Vac for baseplate mounted 7750, 7760, 78XX. 24Vac for 72XX UCs, 7716
XFMR6 Transformer, 120Vac Primary, 24Vac @ 2.4A Secondary 72XXUC, 7716, 7718, 7780, DPU3100, DPU7910A, DPU7920
XFMR7 Transformer, 240Vac Primary, 24Vac @ 2.4A Secondary 72XXUC, 7716, 7718, DPU3100, DPU7910A, DPU7920
XFMR8 Transformer, 120Vac Primary (plug-in), 13.5Vac Secondary (DIN connector) 7750, 7760, 78XX TAPs
XFMR9 Transformer, 277Vac Primary, 24Vac @ 2.4Vac Secondary 7780 DLCU
XFMR10 Transformer, 120Vac Primary, Dual 24Vac @ 2A Secondaries 7728 I/SITE I/O
XFMR11 Transformer, 240Vac Primary, Dual 24Vac @ 2A Secondaries 7728 I/SITE I/O
  • TAC INET
  • 5394
