Transfer EBO 2022 or higher data to Azure IoT hub via MQTT protocol
  • Transfer EBO 2022 or higher data to Azure IoT hub via MQTT protocol
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2022-09-15 12:41 AM
on ‎2022-09-15 12:41 AM
How to transfer EBO 2022 or higher data to Azure IoT hub via MQTT protocol
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
Need to configure EBO MQTT interface and Azure IoT Hub, so EBO can send MQTT messages to Azure MQTT IOT Hub.
The following video will illustrate how to:
  • Create Azure IoT hub and IoT device using Azure Portal
  • Create IoT interface and Azure MQTT client in EBO
  • Configure the MQTT connection
  • Create and configure a data group
  • Test the connection
Things you need:
  • EBO 2022 or later with valid MQTT license or demo license (Enterprise Server, AS-P or AS-B)
  • valid Azure Subscription with possibility to use free account during testing. For each Azure subscription one IoT hub in the free tier can be created, refer to IoT Hub | Microsoft Azure
  • Visual studio code to be used to test the connection between EBO and Azure IoT hub, can be download from: Visual Studio Code
[video]
  • MahmoudSayed22
100% helpful (5/5)
