Transactions/messages showing up in double, triple, in I/NET with remote clients
  • Transactions/messages showing up in double, triple, in I/NET with remote clients
‎2018-09-07 12:46 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:20 AM
Why are transactions/messages showing up in double, triple, etc in I/NET
TAC INET
I/Net revisions 2.xx
The table linking for each of the reports and establishing a link between RptIndividualHistorz.TenantNdx and the RptCards.TenantNDX
  1. In versions of I/NET when using the I/NET client as a remote client, you must uncheck all the Host Masks on each remote client, otherwise, the Messages and transactions show up multiple times.
  2. If not using a Remote Client, the following solution may help you. Refer to the TCON301.
  • TAC INET
Tags (4)
  • 2543
  • Double Transactions
  • Remote Client
  • TomPoovey21
