Trace a connection in a WorkPlace Tech drawing when it is difficult to see the wire path
  • Trace a connection in a WorkPlace Tech drawing when it is difficult to see the wire path
  • sesa119747
    sesa119747
‎2018-09-07 04:44 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-03 01:07 PM
How can a connection be traced in a WorkPlace Tech drawing when it is difficult to see the wire path?
TAC IA Series
WorkPlace Tech
When working with objects that have numerous connection wires (perhaps an uploaded drawing), it may be difficult to see the wire routing path. The link style is too small, which may be difficult to see the wire routing path.
  1. Click on a wire to select it (green handles appear). Two clicks may be required, since the first
    click selects the object that the wire is from.
  2. Right click on the wire and select Format/Style.
  3. In the Line Style pull-down menu, select "Error Box" (a heavy red wire).
  4. Click OK
  5. Trace and edit the connections as needed.
  • TAC IA Series
  • 3621
