Tips to speed up saved searches in StruxureWare Building Operation
  • Tips to speed up saved searches in StruxureWare Building Operation
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 09:05 AM
StruxureWare Workstation
Searches take a large set of objects and check them against text matching and then against conditions. The more you can eliminate before checking text or conditions the better.
Whenever possible use the following methods to speed up searches
  • Use the 'In folder' field to avoid searching too large a section of the system
  • Do not include properties or sub-servers when they are not needed
  • Specify the smallest subset of type you are able to. For example, if you only want Extended Trend Logs, do not use the Base Trend Log object.
  • 17726
