Time Schedules in TAC Xenta Programmable Controllers
  • Time Schedules in TAC Xenta Programmable Controllers
  • MikaelKrantz
    MikaelKrantz
  • sesa150555
    sesa150555
‎2018-09-06 12:29 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-02 05:00 PM
How many time schedules (time objects: TSCH, TSCHI) can be added to TAC Xenta programmable devices?
TAC Vista
  • TAC Xenta 301, 302, 401, 281, 282, 283
  • TAC Xenta 527, 511, 711, 721, 731, 701
  • Menta
The limits for time schedules are not clearly documented across all TAC Xenta controller models, leading to confusion during programming and deployment.
Here are the documented limits for each controller series:
TAC Xenta 7xx Series
  • Supports up to:
    • 50 time objects
    • 50 week schedules
    • 50 holiday schedules
TAC Xenta 28x Series
  • Supports:
    • 1 TSCH block
    • Up to 16 week/holiday charts within that block
TAC Xenta 30x/40x Series
  • No fixed limit on the number of TSCH blocks
  • Limitation is based on available memory
    • More schedules per block = more memory usage
    • Optimize chart usage to conserve memory
🧠 Additional Notes
  • When designing schedules, consider memory constraints especially for 30x/40x series.
  • Use Menta to monitor memory usage during programming.
  • For best practices, avoid overloading a single TSCH block with excessive charts.
Tags (4)
  • 7677
  • MikaelKrantz25
  • Time schedules
  • Xenta controllers
