Third party software on my I/NET PC
  • Third party software on my I/NET PC
‎2018-09-06 10:53 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
Can I run third party software on my I/NET PC
I/NET Site
Third party software on same pc as I/NET
TAC software is delivered for use on IBM and compatible PCs. While your PC is capable of running other third party software while running I/NET, trying to do so may present general operational difficulties. This is particularly true if the other third party software is memory resident. When used as it is intended, the TAC software is also memory resident. The use of more than one memory resident program at the same time may impose unresolvable PC system parameter conflicts and may cause one or more of the memory resident programs to fail. Refer to TCON 300.
  • TAC INET
  • 1224
