Thermistor temperature readings are 10-20°F below actual temperature
  • Thermistor temperature readings are 10-20°F below actual temperature
  • sesa139513
    sesa139513
‎2018-09-06 03:14 PM
I/NET Site
One of the universal inputs on this controller is using a 4-20ma sensor whose resistor input configuration has a 10K ohm in the B-slot instead of a 249 ohm in the A-slot.
  • TAC INET
  • 1628
