The window used to change override time for an S-Link sensor is grayed out. How is the override time changed?
  • The window used to change override time for an S-Link sensor is grayed out. How is the override time changed?
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:51 PM
WorkPlace Tech 5.7.2, MN-S3, MN-S4, MN-S5
Trying to change override time with Workplace Tech 5.7.2.
The ability to change the S-Link sensor override time was corrected in WorkPlace Tech 5.7.5
Upgrade to WorkPlace Tech 5.7.5 or higher
  • TAC IA Series
  • 7022
