The vertical scale (y-axis) in an R2 chart/log is limited to the range of 0 - 0.2, but the values in the log/ table are of a much wider range; e.g. 0.66 - 87.33.
  • The vertical scale (y-axis) in an R2 chart/log is limited to the range of 0 - 0.2, but the values in the log/ table are of a ...
  • SESA113595
    SESA113595
‎2018-09-11 01:27 AM
R2 chart/ log data
Initial testing shows that the y-axis scaling issue is caused by data value of NA in the log table.
As a work around, backup the station, export the .xml file. Search it for data = NaN.  Edit the line in the file so the data no longer shows NaN.
  • TAC IA Series
  • 13119
