The notification Servlet does not work in the Enterprise Server station
  • The notification Servlet does not work in the Enterprise Server station
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:44 PM
NotificationServlet settings and SWID to the output object.
Double check to make sure the SWID to the output object is correct. Set the NotificationServlet - properties - config - "activeCommand" to emergencyActive or manualActive and the "inactiveCommand" to emergencyInactive or manualInactive.
The "activeInactiveText" for the BO can be modified to make that more meaningful.
Reboot the UNC to make these changes take effect.
  • TAC IA Series
  • 3164
