The error message "java.lang.ClassNotFoundException: tridium.services.DatabaseService" is displayed in the Standard Output Window of an UNC when attempting to install...
  • The error message "java.lang.ClassNotFoundException: tridium.services.DatabaseService" is displayed in the Standard Output Wi...
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:08 PM
The following error message is displayed in the UNC-s Standard Output Window when attempting to install a station:
FATAL: Cannot boot station from sns
Niagara R2, UNC-520, UNC-410
A UNC can not be licensed for DatabaseService.
Open the station offline and remove the DatabaseService.
  • TAC IA Series
  • 8321
