The difference between the IDisc wand for I/NET 4.xx and I/NET 1.xx or 2.xx systems
  • The difference between the IDisc wand for I/NET 4.xx and I/NET 1.xx or 2.xx systems
  • sesa139513
    sesa139513
‎2018-09-06 03:23 PM
Is there a difference between the IDisc wand for I/NET 4.xx and I/NET 1.xx or 2.xx systems?
I/NET Site
Yes, there is a difference. In the I/NET 4.xx system, the Dongle (the Gray plug) is a 25-pin connector. This connector also contains a circuit board that is only compatible with I/NET 4.xx. In the I/NET 1.xx and 2.xx systems, the Dongle is a 9-pin connector. This also contains a circuit board that is only compatible with I/NET 1.xx and 2.xx systems.
  • TAC INET
  • 1264
