The content of XBuilder is not correct due to mismatch of the XBuilder version
  • The content of XBuilder is not correct due to mismatch of the XBuilder version
‎2018-09-10 01:08 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
When importing an old database into a new version of Vista, right click on a Xenta Server and select "Edit" to open the Xbuilder project. (Change the version information in the property of Xenta Server. Refer to "Edit" is not available in the right-click menu for a Xenta Server in Vista Workstation.) The old XBuilder project will automatically be upgraded to match the new version of XBuilder. However, the content of the project sometimes will be incorrect after this conversion.
TAC Vista
  • Vista Workstation
  • XBuilder
The XBuilder version of old the database does not match the one of the new database.
  1. Install the old version of XBuilder.
    •  One PC can install several different versions of XBuilder. The standalone XBuilder installation file can be found on the Schneider Electric Exchange Extranet under "Engineering Tools"
  2. Keep the Vista Server and Workstation etc. at the newer version.
  • 5735
