The computer hardware for a SIGNAL installation has changed and there are no parallel ports for the security plug. Is there a USB key for SIGNAL?
  • The computer hardware for a SIGNAL installation has changed and there are no parallel ports for the security plug. Is there a...
  • sesa119747
    sesa119747
  • sesa116868
    sesa116868
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:49 PM
  • Computer without parallel ports
  • SIGNAL
Computer hardware limitation prevent the use of security plug.
As noted in Product Announcement PA-00280, Signal support ended on June 30, 2014.  Replacement parallel port and USB keys are no longer available.
Yes. Here are the part numbers:
SIG-USB-CHG -> (OBSOLETE) Replaces the parallel security plug with a USB version for an existing SIGNAL installation. Contact Customer Service to order this part.  It is not available via iPortal.
SIG-USB-KEY -> (OBSOLETE) Replaces the parallel security plug with a USB version for a new SIGNAL order
  • TAC IA Series
  • 2965
