The Sun JRE VM Module shows "Out of Date" after Installation of Niagara G3 version 3.4.57 or 3.5.25.
  • The Sun JRE VM Module shows "Out of Date" after Installation of Niagara G3 version 3.4.57 or 3.5.25.
  • sesa116871
    sesa116871
‎2018-09-07 03:19 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-17 07:04 AM
After installation of G3 Workbench version 3.4.57 or 3.5.25, the Software Manager on the Localhost may display that the sun-jre-win-x86 VM module is out of date:
  • Niagara G3 version 3.4.57 or 3.5.25
  • Sun JRE VM Module
While this is not a fatal error condition, the module can be updated.
NOTE: if the installed version is 3.5.25, replace path references to "3.4.57" in the paths with "3.5.25"
  1. Shut down Workbench
  2. Open Windows Explorer, and navigate to the C:\niagara\niagara-3.4.57 directory
  3. Rename the jre folder to jre.old
  4. Now, navigate to the C:\niagara\niagara-3.4.57\sw\1.6.0.20 directory. Using WinZip, open the sun-jre-win-x86.dist file (or the sun-jre-win-x64.dist file if using the 64-bit version of Workbench). Select all of the folders in the archive, and extract them to the C:\niagara\niagara-3.4.57 directory (see below). Make sure that the “Use folder names” (or equivalent) box is checked. After the extraction, a new jre folder is created.
  5. Run the Platform Daemon (Start > Programs > Enterprise Network Server 3.4.57 > Install Platform Daemon)
  6. Open Workbench, and then open the Software Manager in the Platform. The Sun VM will now show "Up to Date"
  • TAC IA Series
  • 3941
