The Status of Door Point doesn't Change when Swiping Card
  • The Status of Door Point doesn't Change when Swiping Card
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 12:54 PM
When swiping card, the status of door point in Controller Summary doesn't change.
I/NET
This is so designed in I/NET
In I/NET, the status door point doesn't change when swiping card. So if interaction with swiping card is needed, you need to use Access Initial Control or create another real External point for the door point. (00/01 Ext apart from 08/09 Int)
  • TAC INET
  • 6914
