The Station buttons are missing in the MCU Configuration dialog box
  • The Station buttons are missing in the MCU Configuration dialog box
‎2018-09-06 11:26 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
I/NET 2000 Site
The Station buttons are missing in the MCU Configuration dialog box. What happened?
To provide you with the ability to configure or hide the statistical features of I/NET 2000, there are three .reg files included in the I/NET 2000 application root directory. When you double-click the desired *.reg file, it will update the DiagnosticFlag in the registry to the associated condition.
Each file and its function is as follows:
  • NoStats.reg - No statistics dialog shown,
  • Stats.reg - Shows statistical data but does not allow back-ground ASC resets or manual MR/ASC resets,
  • Stats&Reset.reg - Shows statistical data with ability to perform background ASC resets or manual MR/ASC resets.
For more information see TCON 217.
  • TAC INET
  • 1387
