The SQL Server System Configuration Checker cannot be executed due to WMI configuration on the machine "machinename" error:2147942405(0x80070005).
  • The SQL Server System Configuration Checker cannot be executed due to WMI configuration on the machine "machinename" error:21...
  • sesa150561
    sesa150561
‎2018-09-06 10:34 AM
Unable to install the SQL Server with I/NET. Error shows:
I/NET Seven
Some security settings have been changed under DCOM. If local launch and local activation properties are set to 'Not Defined,' the installation will fail.
  1. Open Administrative Tools > Local Security Policies
  2. Find Local Policies > Security Options > 'DCOM: Machine Launch Restriction in Security Descriptor Definition Language(SDDL)'
  3. Set the System user 'Local Launch' and 'Local Activation' to ALLOW.
  • TAC INET
  • 12788
