The SIGNAL serial numbers on the security plug and the first installation diskette are different. Will they work together?
  • The SIGNAL serial numbers on the security plug and the first installation diskette are different. Will they work together?
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:49 PM
  • SIGNAL computer
  • Security plug
  • installation diskette
Information about the date code found on SIGNAL system.
Every SIGNAL serial number is 8 digits long. The first 4 digits are a datecode and the second 4 digits are the actual serial number:
Serial# xxxx-yyyy
where x = datecode  and y = serial number
The first 4 digits will differ if either the original security plug or original installation diskettes were lost and replaced. As long as the last 4 digits are identical, they will work together.
  • TAC IA Series
  • 2966
