The Niagara shortcut does not appear on the desktop after installing Workbench.
  • The Niagara shortcut does not appear on the desktop after installing Workbench.
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:29 PM
The Niagara shortcut does not appear on the desktop after installing Workbench.  Also the shortcuts do not appear in the Niagara folder under Start - All Programs.
Niagara G3 (all versions)
The setup file was run from the compressed file. When downloaded, Niagara builds are saved to the computer’s hard drive as a compressed folder.
Compressed files must first be extracted before the setup file should be run.
  1. Right-click and extract all files from the compressed folder
  2. Uninstall the version of Workbench with the shortcut issue
  3. Run the extracted copy of the setup program.
The shortcuts should now appear on the desktop and in the Niagara folder under Start – All Programs.
  • TAC IA Series
  • 5799
