The Niagara R2 lib-2.301.532.v1.jar file is missing program objects.
  • The Niagara R2 lib-2.301.532.v1.jar file is missing program objects.
‎2018-09-10 02:06 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
The lib-2.301.532.v1.jar file is missing objects that were present in previous builds.  Here is list of those objects:
lib\programObjects\hvac\RemainingOverrideTime.sns
lib\programObjects\hvac\StartupInhibitor.sns
lib\programObjects\hvac\TriStateOutput.sns
lib\programObjects\lon\BooleansToMfgNvTypeBits.sns
lib\programObjects\lon\BooleansToSnvtStateTypeBits.sns
lib\programObjects\lon\FloatToSnvtHvacModeEnum.sns
lib\programObjects\lon\MfgNvTypeBitsToBooleans.sns
lib\programObjects\lon\SnvtLevDiscEnumTransposition.sns
lib\programObjects\lon\SnvtStateTypeBitsToBooleans.sns
lib\programObjects\lonHoneywell\XL15AnvoFTStatusDemux.sns
lib\programObjects\lonHoneywell\XL15AnvoLogicOutputDemux.sns
lib\programObjects\lonHoneywell\XL15AnvoStStpStatusDemux.sns
lib\programObjects\miscellaneous\MinMaxAvg.sns
lib\programObjects\miscellaneous\NumberRamp.sns
lib\programObjects\miscellaneous\PulseGenerator.sns
lib\programObjects\miscellaneous\WatchdogTimer.sns
lib\programObjects\muxDemux\DateTimeDiscreteComponents.sns
lib\programObjects\muxDemux\ExtractTextSegment.sns
lib\programObjects\muxDemux\ParseString.sns
Niagara R2 version 532
A compiling error with the jar file.
This error has been corrected in a new 'lib' jar file: lib-2.301.533.v1.zip.
  • TAC IA Series
  • 6020
