The MNB-300 mounting base, manufactured before January 2009, does it comply with the UL 864 standard?
  • The MNB-300 mounting base, manufactured before January 2009, does it comply with the UL 864 standard?
  • sesa119747
    sesa119747
‎2018-09-06 02:36 PM
  • MNB-300 mounting base
  • UL 864
Information on MNB-300 compliant with the UL 864 standard.
The MNB-BASE-300 has electronics on it that cannot be used for smoke control if it has a manufactured date prior to receiving UL 864 certification (January 2009).
  • TAC IA Series
  • 3527
