The BDelay object from the LonWorks jar conversion library intermittently shows very large "remaining time" causing logic issues.
  • The BDelay object from the LonWorks jar conversion library intermittently shows very large "remaining time" causing logic iss...
  • Kim_Baze
    Kim_Baze
‎2018-09-06 10:20 AM
R2, UNC's
The BDelay object does not initialize the time remaining properly under some conditions.
In the Lib jar - programObjects - hvac folder there is a program called DelayedOutput.sns.  This program can do the delayed on and off function but will need to be enhanced if the time remaining output is required.
  • TAC IA Series
  • 13478
