Text in I/NET is showing up as gibberish, but the text in the SQL database looks OK
  • Text in I/NET is showing up as gibberish, but the text in the SQL database looks OK
  • sesa150561
    sesa150561
‎2018-09-06 10:31 AM
I/NET
If you upgrade I/NET and the SQL database but do not use DBcreate, the text in I/NET can become gibberish.
Restore/upgrade the database with the help of DBcreate (follows I/NET )
  • TAC INET
  • 12887
