Test a REST gateway in SmartConnector using Swagger
  • Test a REST gateway in SmartConnector using Swagger
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2023-09-11 06:50 PM
on ‎2023-09-11 06:50 PM
After setting up a REST gateway in SmartConnector, how can it be tested to see that it is working using the built in test client called Swagger?
  • Building Operation Enterprise Central
  • SmartConnector
Swagger is a built in test REST client which can be used to read and set values in EBO.
So it can be used instead of a "real" REST client to test the REST gateway in the SmartConnector and test that the connection between SmartConnector and EBO is working.
The objective in this video is to set up a REST gateway in SC and show how we can test that the gateway is working using the built in test REST client called Swagger.
Please see video.
[video]
100% helpful (1/1)
