Termination resistor values
  • Termination resistor values
  • sesa139513
    sesa139513
‎2018-09-06 03:14 PM
What value resistors should be used as termination resistors?
I/NET site
On a controller LAN, use 100 to 120 ohm resistors.
If a repeater is installed, or controllers are being installed on a subLAN, use 620 ohm resistors.
  • TAC INET
  • 1626
