Tap not communicating with Host
  • Tap not communicating with Host
‎2018-09-07 12:07 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
Tap not communicating with Host. (Refer to TCON 101 and TCON 226)
I/NET
7801 Tap
Multiple causes are possible.
  1. Check connections at the host port
  2. Verify Switch settings
  3. Ensure you are using the correct cable
  4. Check the Tap version
  5. Check the Baud rate set in the set up
  6. Check the Comm Port defined in setup
  • TAC INET
  • 1473
