Tacos not responding when starting Workstation
  • Tacos not responding when starting Workstation
  • sesa150561
    sesa150561
‎2018-09-06 09:55 AM
  • Vista
  • Tacos.exe
If a trendlog is manually on but does not have a value to log, it can cause Tacos to crash (not responding).
  1. Go to the TAC Vista Installation folder
  2. Find the file named TACaddon01.DLL
  3. Rename TACaddon01.DLL to TACaddon01OLD.DLL and start Vista Server and Workstation again.
  4. Search for all trendlogs and make sure they have a point to read from, if not set them to manually off.
  • 14826
