TTS 100 Series Thermistor Sensor
  • TTS 100 Series Thermistor Sensor
  • sesa139513
    sesa139513
  • SESA128071
    SESA128071
‎2018-09-06 03:10 PM
I/NET Seven Site
Conversion coefficient is for a Thermistor for a particular controller, and can it be used with the new controllers such as MRs/Motorola and HID/Dorado card readers
TTS100 SERIES THERMISTOR SENSORS
Dale 1M1002-C3 Curve 1
Product Support Services continues to get calls asking what the conversion coefficient is for a Thermistor for a particular controller, and can it be used with the new controllers such as MRs. Therefore we have consolidated into this Tech Tip the variety of ways the Thermistor Series Temperature Sensors can be used with Schneider Electric's current family of controllers, including wiring, controller input range and conversion coefficients for both degrees Fahrenheit and Celsius. It makes for a great quick reference. Keep it handy.
MR123-210(A), 430(B), 032(C), 400(D) "I/STAT PORT ONLY"
MR88 (F), MR632 (G), MR160 (H), MR88R (K) "I/STAT or UI Inputs"
Counts
Input
Range
Read
Range
M
Slope
B
Intercept
Temperature
Range
Span
0 - 255
0 - 5 vdc
0 - 5 vdc
0.018
-148
-40 - 176°F
Normal
0.01
-100
-40 - 80°C
Normal
102 - 204
2 - 4 vdc
2 - 4 vdc
0.018
-148
32 - 90°F
Narrow
0.01
-100
0 - 32°C
Narrow
MR55 / 55X (J)
Counts
Input
Range
Read
Range
M
Slope
B
Intercept
Temperature
Range
Span
0 - 255
1.5 - 4 vdc
1.5 - 4 vdc
0.018
-148
25 - 113°F
Normal
0.01
-100
-4 - 45°C
Normal
Look-up Table #1 if wired to the I/STAT Port
Look-up Table #2 if wired to one of the Universal Input -Plug a 10K in B slot
Red - Signal In, Green - Ground
I/NET 7700 SERIES CONTROLLERS
Accuracy: +/- 0.2 DegC @ 25 DegC, Nominal Resistance: 10,000 Ohms @ 72 DegF
Operating Range:
TSS100WJ, D1, D2, I1, I2, S1, S2,SP, SS: 32 to 158 DegF ( 0 to 70 DegC)
TSS100OA: -4 to 158 DegF ( -20 to 70 DegC )
TSS100W: 32 to 122 DegF ( 0 to 55 DegC)
Power Requirements: 5 Volts excitation via 10K Ohm Resistor
Negative Temperature Coefficient ( Dale 1M1002-C3 Curve 1 )
*7716 PCU, 7718 PCU, 7728 I/SITE I/O, 7756 PCU (Upper Board Only)
Counts
Input
Range
Read
Range
M
Slope
B
Intercept
Temperature
Range
0 - 4095
0 - 5 vdc
0 - 5 vdc
-0.1
300
-40 - 230°F
-0.05
150
-40 -110°C
819C/V (10K in B slot)
Red - Signal In, Green - Ground, DegF / DegC - See LUT Chart
*7716 PCU Rev. J boards ONLY
7756 PCU (Lower Board Only)
Counts
Input
Range
Read
Range
M
Slope
B
Intercept
Temperature
Range
0 - 32767
0 - 10 vdc
0 -5 vdc
0.018
-148
-40 - 230°F
0.01
-100
-40 -110°C
6553.5C/V (10K in B slot)
Thermistor Sensors Look-up Table Chart
7716, 7718, 7728, 7756 (Upper Board)
Fahrenheit Thermistor   Celsius Thermistor
# Count Adj Count   # Count Adj Count
1 153 521   1 153 601
2 344 1062   2 344 1202
3 816 1604   3 816 1804
4 1245 1875   4 1245 2105
5 1827 2146   5 1827 2406
6 1914 2182   6 194 2446
7 2003 2218   7 2003 2486
8 2048 2236   8 2048 2506
9 2093 2254   9 2093 2526
10 2183 2290   10 2183 2566
11 2274 2326   11 2274 2606
12 2366 2361   12 2366 2646
13 2457 2397   13 2457 2686
14 2548 2433   14 2548 2726
15 2637 2469   15 2637 2766
16 2725 2505   16 2725 2806
17 2812 2541   17 2812 2845
18 2897 2577   18 2897 2885
19 3209 2756   19 3209 3084
20 3577 2934   20 3577 3283
21 3923 3293   21 3923 3681
7756 (Lower Board)
Fahrenheit/Celsius Thermistor
# Count Adj Count
1 128 32846
2 2048 20039
3 4096 17584
4 6144 16185
5 8192 15180
6 10240 14373
7 11264 14016
8 12288 13681
9 13312 13363
10 14336 13058
11 15360 12191
12 16384 12474
13 17408 12191
14 18432 11910
15 19456 11629
16 20480 11346
17 21504 11058
18 22528 10762
19 23552 10455
20 24576 10132
21 28624 9412
22 28672 8514
23 30720 7161
24 32640 2438
  • TAC INET
  • 1825
