TGML/hyperlink - When opening a hyperlink you get message that a version higher or equal than 9 is needed for Internet explorer
  • TGML/hyperlink - When opening a hyperlink you get message that a version higher or equal than 9 is needed for Internet explor...
  • sesa150561
    sesa150561
‎2018-09-11 05:07 AM
  • Cant open a hyperlink because internet explorer version is to low
  • Vista
The hyperlink is opened with compatibility mode on please read more here
1) http://stackoverflow.com/questions/6717055/how-do-i-turn-off-compatibility-view-on-the-ie-webbrowser...
2) http://msdn.microsoft.com/en-us/library/ee330730(v=vs.85).aspx
Open regedit
  1. Go to Start > Run
  2. Enter regedit and press enter
  3. Locate the folder
    • 32-bit OS:
      HKLM\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION
    • 64-bit OS
      HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\MAIN\FeatureControl\FEATURE_BROWSER_EMULATION
  4. Right click and choose add
  5. Add a DWORD
  6. Name it "TACVistaExplorer.exe"
  7. Enter the value depending what Internet explorer you use
    i.e for Internet Explorer 10 enter the value 10001
  8. Restart Vista and Tacos
    This is how it should look
  • 13653
