TGML Objects are no longer highlighted when dragging and dropping snippets to the graphic editing pane.
  • TGML Objects are no longer highlighted when dragging and dropping snippets to the graphic editing pane.
  • sesa177673
    sesa177673
‎2018-09-10 06:16 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-06-03 06:53 AM
TGML Objects are not highlighted when dragging and dropping snippets to the graphics editing pane. If a number of objects are close together, it can be difficult to see which object the snippet is being dropped on to.
TAC Vista
TAC Vista 5.1.7
TGML editor 5.1.7
Updates to the TGML Editor in 5.1.7 removed this feature.
The item which the mouse-pointer is hovering over is highlighted in the TGML menu tree in later versions. An upgrade will restore this functionality.
As a workaround in version 5.1.7, snippets can be dragged directly to the desired object in the Objects Pane as opposed to the editor workspace to ensure the proper object is selected.
  • 7215
