TGML - Can not see "My Components" in TGML editor
  • TGML - Can not see "My Components" in TGML editor
  • sesa150561
    sesa150561
‎2018-09-06 02:07 PM
  • Components library disappearing if the TGML graphic editor is closed and then reopened.
  • When adding a custom folder to the components library, the new folder shows up in the graphic editor, but if the editor is restarted, they disappear.
  • Vista
  • TGML Editor
TGML can not handle a dot "." in the naming
When creating a folder in My components its important to not have a "." dot in the name. When restarting the editor it will try to reread the folders but will stop because of the "." To correct this remove the "." in the name of the folder
Remove all dot's in the name of the Components folder
Wrong:
My own components V2.0
Right:
  • 4645
