TAC Xenta 102-AX PlugIn gives error message in EBO
  • TAC Xenta 102-AX PlugIn gives error message in EBO
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2021-11-23 11:27 AM
on ‎2021-11-23 11:27 AM
Could not start the TAC Xenta 102-AX LonWorks PlugIn, due to an Error message.
EcoStruxure Building Operation.
  • EcoStruxure Building Operation Workstation.
  • TAC Xenta 102 AX
EcoStruxure Building Operation does not support online PlugIns, as LNS is running in the background, without any communication port.. If selecting to Synchronize (Upload or Download) you will get an error message.
Select "Skip" synchronize.
  • MikaelKrantz21
