TAC Vista SmartStruxure Interface DCOM and firewall settings
  • TAC Vista SmartStruxure Interface DCOM and firewall settings
  • sesa150555
    sesa150555
‎2018-09-06 09:07 AM
  • When using the SmartStruxure Interface, is it necessary to configure any DCOM or firewall settings to run TAC Vista and SmartStruxure on different computers?
  • What protocol is used for communication between the SmartStruxure interface for TAC Vista and the ES?
EcoStruxure Building Operation, TAC Vista
  • TAC Vista server
  • SmartStruxure Enterprise Server (ES)
Communication issues between interface and SBO
  • Only HTTP/HTTPS are used.
  • You can configure the interface to use only one of the protocols.
  • You can also configure what ports to use.
Labels (2)
  • 17650
