TAC Vista 5.1 installation hangs on installing Video Functions. CPU is at 100% and the installation will never finish.
  • TAC Vista 5.1 installation hangs on installing Video Functions. CPU is at 100% and the installation will never finish.
  • sesa150555
    sesa150555
‎2018-09-06 02:38 PM
Vista Installation
It seems like the MSI process for the Video components sometimes gets into a loop.
  1. Start the installation and let it run until it “hangs"
  2. Go into Task Manager-Processes and end the process “msiexec” that is using all the CPU.
  3. The installation should proceed and everything should be installed correctly
  • 3396
