TAC Menta, mainloop overrun then having many Alarm blocks and more than one ERR block.
  • TAC Menta, mainloop overrun then having many Alarm blocks and more than one ERR block.
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:03 AM
TAC Menta could give mainloop overrun then having an application with many Alarm blocks and more than one ERR block.
TAC Xenta 280/300/401
TAC Menta
When the ERR block is executed, it goes through all Alarm blocks to check status, having more than one ERR block makes this loop to be run more than once.
There sould be a maximum of one ERR block per application.
  • 17828
