TAC Menta, Changing name on a HFB I/O-block in an HFB removes the connections
  • TAC Menta, Changing name on a HFB I/O-block in an HFB removes the connections
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 12:54 PM
TAC Menta, Changing name on a HFB I/O-block in a HFB removes the connections
  • TAC Menta
  • Hierarchal Function Block (HFB)
Then a HFB IO-block is renamed, it loses its connection to other blocks.
  1. Disconnect the connections from the HFB IO-output
  2. Place the connection next to the HFB block
  3. Rename the output of the HFB
  4. Re-connect the HFB IO-output.
  • 6900
This is a heading
