TAC Dump Helper for TAC Server
  • TAC Dump Helper for TAC Server
  • Sacco
    Sacco
‎2018-09-07 02:06 PM
In some instances, Product Support Services may require you to execute this batch file to record Vista Server errors. This is not a required file and should only be executed under the direction of PSS.
  • TACDumpHelper
  • Vista Server
Vista Server fails to run correctly
To run TACDumpHelper, the batch file is to be run manually.
  1. Unzip TacDumpHelper to a directory of your choice. TACDumpHelper_v1.0.zip or TACDumpHelper_v1.1.zip (64bit)
  2. Start Tacos.exe (Vista Server)
  3. Run start.bat
  4. Choose to monitor a crash - Press 2
  5. Choose which process to monitor - Tacos.exe - Press 1
  6. Wait for the application to crash.
  7. The dump files will be saved in the same folder where start.bat is located.
TACDumpHelper v1.1 64bit.zip
  • 4871
This is a heading
