System tree pane not working in webstation
  • System tree pane not working in webstation
  • DavidChild
    DavidChild
  • sesa150555
    sesa150555
‎2018-09-07 09:04 AM
Get failed "Unable to locate path /your/path/../ Either the path is invalid or the location is currently offline"
Building Operation Webstation
If the root path is changed in a workspace then the issue below occurs.
Webstation is trying to locate the system pane in the folder indicated in the Root path.
  1. Go to Server > System > Domains > Your domain > Workspaces
  2. Click on the workspace that us used
  3. Click on the content tab
  4. Change the root path back to ~
Tags (3)
  • 14038
  • DavidChild19
  • tilde
0% helpful (0/3)
